Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Footprints in custom library defaulting to 60 mil after saving project files then re-opening.
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 529 views
tw234
tw234 over 9 years ago
I am using a custom PCB libary in our current design for plug connectors and type 33 LEDs. The problem is that vias and or pads in the pcb lirary part always defaults to 60 mil dia. when specced to 50 or 55 mil dia. and the libary is saved and changes uploaed to the PCB design and saved. Upon re-opening the project or the PCB library the footprints either fault or default back to 60 mil and the PCB footprint size has to be redone. It is a problem having to do this continually. Any suggestions or fixes to this problem? Cheers.
  • e14softwareteam
    0 e14softwareteam over 9 years ago
    Thanks for bringing this to our attention.  I will check with the developers and see if they can comment on this.
    Tony
  • e14softwareteam
    Here is the response from the developers:
    "This is planned to be added in version 1.4 (planned for Jan/Feb 2017) so that when the Tab button is pressed and values are entered, this will be stored for next time (in default primitives)."
    Tony
