Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum PCBDOC in CS creates multiple windows
  • Locked Locked
  • Answers 2 answers
  • Subscribers 91 subscribers
  • Views 1245 views
bestboy4
bestboy4 over 9 years ago
I am trying to open PCBDOC in CS version 1.4 that was originally created in Designer 14.3.  I converted the file to PCB 5.0 Binary.  However, I am getting a ugly outcome in CS.  When I open the PCBDOC in CS, CS will open a seemingly infinite number of instantiations of CS (i.e. multiple windows).  The only way to stop it is to shut my computer down and restart.  Has anyone else experienced this?
  • yadhu22krish@gmail.com
    yadhu22krish@gmail.com over 9 years ago +1 suggested
    Hi Andrew, Even after you saved as PCB 5.0 Binary you need to do one more thing to open the file in CS. You need to Import the same.While import go for PCBDoc 5.0 and 6.0 Binary files. Refer to this link…
  • bestboy4
    bestboy4 over 9 years ago in reply to yadhu22krish@gmail.com +1
    Can I use the import function if I have a trial version of CS? It is greyed out under the "File" drop down menu.
    yadhu22krish@gmail.com over 9 years ago in reply to bestboy4 +1 suggested
    Yes . You can use the same to import PcbDoc files.
  • jimku
    0 jimku over 9 years ago
    I'm not sure if this applies to your issue but did you "open" or "import" the file? I believe someone else reported a similar problem when they tried opening a pcbdoc file but was successful after importing the file.
    0 yadhu22krish@gmail.com over 9 years ago
    Hi Andrew,
    Even after you saved as PCB 5.0 Binary you need to do one more thing to open the file in CS. You need to Import the same.While import go for PCBDoc 5.0 and 6.0 Binary files. Refer to this link. Importing Altium Circuit Studio files to Altium Designer and Vice Versa
  • bestboy4
    0 bestboy4 over 9 years ago in reply to yadhu22krish@gmail.com
    0 yadhu22krish@gmail.com over 9 years ago in reply to bestboy4
