Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Exporting into .step file.
  • Locked Locked
  • Replies 7 replies
  • Subscribers 89 subscribers
  • Views 3481 views
  • step
  • 3d printed
yadhu22krish@gmail.com
yadhu22krish@gmail.com over 9 years ago
Whatever be the color of the board, when I try to export into step it becomes green.Is it so or am I doing anything wrong ?
  • e14softwareuk
    e14softwareuk over 9 years ago in reply to yadhu22krish@gmail.com +1 verified
    I understand better now, you are not changing the colour in CircuitStudio because you do not have the choices. There is a forum post that adds in the extra colours, see the last answer on this thread …
  • e14softwareuk
    0 e14softwareuk over 9 years ago
    Hi. I've just tested this and it seems to work correctly. Loaded an existing PCB, changed the colour using View > Switch to 3D > View Configurations > Altium 3D Blue and then exported to a STEP file. Loaded this into the free Autodesk viewer and the board substrate was blue.
  • yadhu22krish@gmail.com
    0 yadhu22krish@gmail.com over 9 years ago in reply to e14softwareuk
    I tried the same. Changed the color View > Switch to 3D > View Configurations > Altium 3D Blue ......But when i tried to open the step file in Fusion 360 and tried to place the step file for another component it goes back to green.
  • e14softwareuk
    0 e14softwareuk over 9 years ago in reply to yadhu22krish@gmail.com
    Just tested and the PCB came in blue as expected. Does your board come in the correct colour to start with and only change when you try importing additional step files?
    In my cs it can only be changed to black.
    View > Switch to 3D > View Configurations > Altium 3D Black
    this is the option I have.But i need the boards in blue and red.
    Is there any way ?
    Is there any way ?
  • e14softwareuk
    I understand better now, you are not changing the colour in CircuitStudio because you do not have the choices. There is a forum post that adds in the extra colours, see the last answer on this thread.
    now i understand.Let me try the same. Thanks for your info.
