Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Part Search In Schematics
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 2056 views
tw234
tw234 over 9 years ago
Having problem with the part search in CS, sometimes the part search for components works when searching in the shematics documnets but usually defaults to the PCBDoc. Sometimes rebooting the programme works but usually not. Got round it by using text search, but this seems to work only if the components that are being searched for are the on schdoc that is currently being used. Can this be sorted as it is a pain using text search to find components on a large shematic. I am using the most up to date version.
Cheers.
  • tw234
    tw234 over 9 years ago +1
    Hi peter, compiling seems to have sorted the issue. Cheers, T.
  • e14softwareuk
    e14softwareuk over 9 years ago in reply to tw234 +1
    That's great news. One thing to remember is that you will probably need to compile each time you start CircuitStudio, the compile is not run automatically when CS starts or opens the project.
  • yadhu22krish@gmail.com
    0 yadhu22krish@gmail.com over 9 years ago
    Hi tony,
    I had tried to search for parts. Didnt had any problems.
  • e14softwareuk
    0 e14softwareuk over 9 years ago
    Hi Tony, assuming you are using the search box at the top right of the main window. From the schematic editor Home > Project > Compile and then the search should find components in your schematic sheets as well as your PCB.
  • tw234
    0 tw234 over 9 years ago
    Hi peter,
    Cheers,
    T.
  • e14softwareuk
    0 e14softwareuk over 9 years ago in reply to tw234
