Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum PCB Templates
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1391 views
  • pcb layout
  • templates
PCB Templates
cheriton
cheriton over 8 years ago
I have recently moved to Circuit Studio from Protel 99SE and am mostly enjoying the extra features while not having too steep a learning curve as it's quite similar to my old system.
My only real issue is that I've lost the old Protel PCB wizard which used to generate a template for my PCBs with our logo, board name, date, revision, etc,. etc..
I have looked extensively through CS's various menus and settings and, unless I'm wrong there is no way of making a new PCB with a template showing the same information as before.
Am I wrong? Is there some way of generating templates for PCBs?
  • alexsander_altium
    0 alexsander_altium over 8 years ago
    Hey John, I have an answer for you but its a bit of a work around as its not in the software as of now. To create a template to CircuitStudio this is what you'll have to do:
    1. create your project you want to use as a template
    2. give the project, sch, and pcb files the same name (file extension can be different)
    example:
    MyTemplate.PrjPCB
    MyTemplate.CSPCBDoc
    MyTemplate.SCHDoc
    3. save these files here: C:\Users\Public\Documents\Altium\CS\Templates\PCB Projects
    4. add to the "PCB Project Templates.ini" file in the same folder as step 3
    using step 2 as an example we would put an entry into the INI as follows
    [MyTemplate]
    Category=Custom
    Title= My custom project template
    Description=Starter PCB w/title block, Schematic with Titleblock, Project with options set.
    (you can also add an EMF image of the same name if you want a visual preview)
    5. Restart / open CircuitStudio
    6. Create a new project : file>new project  Here you should see a custom category in the templates list
    Good luck.
    -Alexsander
  • cheriton
    0 cheriton over 8 years ago in reply to alexsander_altium
    Thanks Alexsander. I'll try that.
    Regards
  • camille0103
    0 camille0103 over 8 years ago in reply to cheriton
    hey John, do you want to look for PCB supplier for the lower cost
