Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Gerber output viewer
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 2248 views
danstock
danstock over 8 years ago
I have generated the gerber output layers but when I open the individual layer files they appear as text only.  Is this because I am using the trial version or am I missing something??
  • adamwebber
    0 adamwebber over 8 years ago
    I also have tried viewing Gerber files using CS.  I can't.  I have used Altium and it has a wonderful Gerber viewer built-in.  I think since this is the cheap version of Altium, they don't include a Gerber viewer.  It wouldn't be all too difficult to put it in there.  If you need to look at your Gerber files, you'll need to either download a third party Gerber viewer or upload your files to one of the many PCB manufacturing websites that show you your layers.  Unless there is something that I am totally missing about CS.  I would also love to view the Gerbers.  It was a great check to see that all of my layers and vias lined up properly.
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    I can confirm that there is no built-in graphical Gerber viewer in CircuitStudio, as suggested by others there are free tools available to use that can be found online.
  • niteowl12
    0 niteowl12 over 8 years ago
    Try using Viewmate form Pentalogix. https://www.pentalogix.com/t/software-products/viewmate Its free and what I use to look at gerbers from an external source.
    I also use the OSHPark import to verify the gerbers. You can import them without having to order.
  • tarribred61
    0 tarribred61 over 8 years ago in reply to niteowl12
    I have used the gEDA viewer; it is easy to enable/disable the various layers with simple checkboxes and it has a measurement tool.  The Altium Gerber viewer was very good and I hope they put it in CS or make it a stand-alone tool to support CS and CircuitMaker.
    https://sourceforge.net/projects/gerbv/files/gerbv/
