Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Custom Title Block and Drawing templates
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 2737 views
  • title block sheet template
dmaruska
dmaruska over 8 years ago
Hi, I'm new to CircuitStudio, How can I create a custom Title block, and how can I edit a sheet template and select it for drawings.  I may want to alter the sheet look and make it look somewhat like SolidWorks Drawing sheets.
Dave M.
  • adamwebber
    adamwebber over 8 years ago +1
    Your schematic templates are located in C:\Users\Public\Documents\Altium\CS\Templates. Your templates have a *.SCHDOT file extension. When you open a schematic template file, you can adjust the title block…
  • adamwebber
    0 adamwebber over 8 years ago
    Your schematic templates are located in C:\Users\Public\Documents\Altium\CS\Templates.  Your templates have a *.SCHDOT file extension.  When you open a schematic template file, you can adjust the title block and sheet size.  Make your adjustments and save it in the template default folder as a *.SCHDOT file.
    Helpful hints:
    CircuitStudio and Altium have a lot of similarities.  Search for Altium help and it works on CS as well.
    Use the drop-down to select much of the text that you want.  ie. =DocumentFullPathAndName or =CurrentDate and it will autopopulate when you create a new schematic.
    Choose your default units.  They can be changed any time but it's nice to start with it the way you want it.
    A lot of this information is transferable to your BOM so make a BOM template in the same manner.
    Now if you want to make your own PCB template, that is a little different.  There is a thread for that.  Click on the link.
    PCB Templates
