Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Moving Tabs
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 804 views
Moving Tabs
adamwebber
adamwebber over 8 years ago
So I started CS yesterday and made a new project with Schematics and PCB.  Then I tried to drag and drop the tabs to the order that I wanted.  And that feature is gone somehow.  It shows that I am dragging the tab but then it doesn't move when I let go of the mouse button.  Is anyone else experiencing a similar glitch?
  • mars01
    0 mars01 over 8 years ago
    Yes, I've seen this behavior and reported it here:
    https://www.element14.com/community/message/233655/l/re-moving-tab-to-new-window-is-not-working#233655
  • andync
    0 andync over 7 years ago in reply to mars01
    Found a work round.
    If you right click the tab you want to move and open in new window, it opens in a new window. OK.
    You can now drag this to the other window you intended to move it to ie your other screen and close the redundant window.
    Tedious!
    I think this is a bug in CS.
    I get many crashes ie the "please wait a moment" box when recompiling intlibs. almost every time.
    I've used Altium for 10 years in previous job and there were always little niggles. "please wait a moment" was very common. There was one where if you created a poly on an internal plane ( I know you shouldn't but I forgot it was a plane and not a layer) it corrupted the pCb design and you had to carefully navigate the mouse to save the pcb as ascii and re-open. If the mouse pointer went onto the design it crashed
    Cheers
    Andy
    Edit:
    Sorry: This only worked once! I can't reproduce it.
