Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Circuit studio errors
  • Locked Locked
  • Answers 2 answers
  • Subscribers 90 subscribers
  • Views 867 views
vaidyaparth
vaidyaparth over 8 years ago
How can I solve duplicate net names wire error in circuit studio?
  • batuu
    0 batuu over 8 years ago
    Net name generation is based on the connected component and pin designators. Take a look at the warnings below the errors. T1 seems to have a duplication in the pin designators (pin 1 and 2). Try to solve this problem first.
  • vaidyaparth
    0 vaidyaparth over 8 years ago in reply to batuu
    T1 is the transformer that I have created. I have checked all pins and its designators and found that they are all different. Duplicate net names wire means?
  • e14softwareuk
    0 e14softwareuk over 8 years ago in reply to vaidyaparth
    Have you eliminated the duplicate pin error yet? If the system still thinks there are duplicates then it will still need fixing. Is your transformer a single symbol or multi-part symbol?
  • batuu
    0 batuu over 8 years ago in reply to vaidyaparth
    On your screenshot I see two pins with the designator 1. (Lower end of the top right inductor and the upper pin of the lower left inductor). Please check, if you mistakenly took "pins" instead of lines to draw the parts of the transformer.
  • vaidyaparth
    Thank you sir, actually when I created my component I attached extra pins being  unaware that inductor symbol that I took already had pins.Due to this it was showing duplicate net names error.
  • vaidyaparth
    0 vaidyaparth over 8 years ago in reply to e14softwareuk
    Yes, I did.
