Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Custom PCB library locks up.
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 535 views
opeongo73
opeongo73 over 8 years ago
I have another problem with CS1.5. I was editing my own library and firstly I changed the footprint name on a chip capacitor. That was okay. Then the moment I hit one of the component border top silk lines the library froze and no components within the library were any longer editable. The only way to recover the library was to load up the previous one before this action. Any thoughts on how to unlock the library?
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    I've tried to reproduce this using the steps mentioned - change the name of a PCB library component then select a Top Silk line and could not reproduce a freeze. If you can please email through the library directly to me and I will take a look on my system to see if I can edit the library or not.
  • opeongo73
    0 opeongo73 over 8 years ago in reply to e14softwareuk
    Hi Peter: I entered your suggestions (View - Clear) and (Home - All Objects) and this solved the problem. Thanks for your suggestion. I will try this on my pcb layout that also is locked up.
    Jim
