Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Circuit Studio PCB Designator Font Default/Change
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1301 views
  • pcb designator font
jtowich
jtowich over 8 years ago
Is there any way to set the default pcb component designator font? The default font is pretty big and I always have to go through each designator one at a time and change them. It would be useful if you could change all at once, but I haven't found how to do this in CS. Surprisingly, I stumbled on a google link that told how this could be done in Circuit Maker. It used the PCB Inspector, but that doesn't seem to work in CS. It seems that if it can be done in Circuit Maker, it should have been added to Circuit Studio as well.
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    Hi Joe, it is possible to set a default prior to placement or adjust all the designators after placement. This is a common questions so we have a dedicated CircuitStudio knowledge base article on the subject.
    Changing Designator Text Properties
