Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Delte entire route
  • Locked Locked
  • Subscribers 91 subscribers
  • Views 904 views
  • pcb editor
  • routing
Delte entire route
_aw
_aw over 8 years ago
Is there an easy way to delete an entire route at once, rather than one segment at a time?
  • mars01
    mars01 over 8 years ago +3 verified
    Home -> Select -> Connected Copper or simply Ctrl+H after clicking on the targeted trace. Click somewhere on that trace and then you hit Delete. In the Search tab there are other possibilities by typing…
  • bugrobotics
    0 bugrobotics over 8 years ago
    You can't delete an entire route with one click (unless of course you highlight all of the segments while holding SHIFT).  You have to select a segment, hold CTRL and then press DELETE as many times as there are segments.
    EDIT: I was wrong.
  • mars01
    0 mars01 over 8 years ago
    In the Search tab there are other possibilities by typing 'select'
  • bugrobotics
    0 bugrobotics over 8 years ago in reply to mars01
    Thanks Marius, didn't even know that command existed.
  • _aw
    0 _aw over 8 years ago in reply to mars01
    Thank you very much!  I'm glad to hear it is possible.
