Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Extension of gerber output files
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1933 views
  • gerber files
_aw
_aw over 8 years ago
I am trying to change the default extension for my layer PCB Specifications... It is currently Assembly Text Bottom (see pic below).  I don't know how it picked that extension name.  I am working on a project that was imported from a sub-contractor that is using Altuim Designer.
Is there any way to change the extension name in CS or are my choices  1) I have to remember to do that manually after gerber files are ploted  2) I need to move my PCB Specification text to another layer that has a better name?  Is there a list of extension names for Gerber layers for CS like there is for AD (https://www.altium.com/documentation/18.0/display/ADES/WorkspaceManager_Dlg-GerberSetup_Form((Gerber+Setup))_AD )?
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    Hi Aaron. The default extension names cannot be changed, you can see the list by looking at the Gerber output setup screen.
  • _aw
    0 _aw over 8 years ago
    Just a side note in case it might help someone else, to see all the extension names that are available, I had to first enable all the layers in the View Configurations dialog (Left click on color box next to LS).
