Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Highlight or underline nets on multiple schematic sheets
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1334 views
  • circuitstudio
  • underline connections
  • schematic editor
jaza_tom
jaza_tom over 8 years ago
I have two schematic sheets in the same project.  Schematic A has a net called "schA_netA" and Schematic B has a net called "schB_netA".  Schematic A connects schA_netA to port called netA.  Schematic B connects schB_netA to a port called netA
If I used the Underline Connections tool to underline schA_netA, the corresponding schB_netA net on the other schematic does not get highlighted.
How can I highlight these two connected nets across schematic sheets?
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    Hi Tom. Try using ALT+CLICK which will highlight across multiple sheets. It sets a mask to that the connect wire segments are highlighted. Only minor issue is that if there is no match it will not automatically clear the mask from the other sheet.
