Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum How can I use CircuitStudio to create a footprint in a way that doesn't make me want to blow my brains out
  • Locked Locked
  • Subscribers 91 subscribers
  • Views 1656 views
  • troubleshooting
  • footprint
  • line
  • pcb editor
  • interactive command line
  • pcb_library
  • command line
  • circuitstudio
jaza_tom
jaza_tom over 8 years ago
I'm just trying to create a footprint, but instead of doing it the "old fashioned way" (changing the snap grid size, zooming way in so that I can use the mouse to place the start of the line to the nearest 0.01 mm mark), I was dinking around trying to do it in a sensical, efficient way.
Most CAD editors I've ever used allow you to define the coordinate of the next point you are placing using keyboard input.  For example, if I wanted to place the next point of a poly-line at X = 6.35 and Y = 6.35 I could type "6.35 mm TAB 6.35 mm ENTER"  using the keyboard, instead of setting the snap grid to 0.01mm and zooming way in near 6.35 mm and then dancing the cursor around the screen while watching the cursor coordinate indicator until both X and Y hit 6.35.
Does CircuitStudio have any functionality that would allow me to simple enter the coordinate for the next point instead of doing this retarding dance?
Alternatively...
I also tried to be more productive by defining some linear guides in my footprint layout.  Big mistake.  That just wastead time, since CircuitStudio does not snap to linear guides (even if you have that option enabled).  Woopsies!  See the video here for proof:
*sigh*
I'm building up quite a repository of CircuitStudio annoyances on my YouTube channel.  Good thing YouTube doesn't seem to impose any sort of limitations on how many MB of CircuitStudio mishaps I upload.
  • jimku
    jimku over 8 years ago +1 verified
    In order to place the first or next point of a poly-line or pad, etc. just use the j key for Jump to Location. Select the pad or line tool then hit the j key. You can also set the grid to 6.35mm for x…
  • voltsandjolts
    voltsandjolts over 8 years ago +1 suggested
    Or use PCB Library expert, free version is OK and makes nice 3D STEP models too. IPC Compliant Footprint Wizard
  • jimku
    0 jimku over 8 years ago
    In order to place the first or next point of a poly-line or pad, etc. just use the j key for Jump to Location. Select the pad or line tool then hit the j key. You can also set the grid to 6.35mm for x and y together or just x or y separately.
  • jaza_tom
    0 jaza_tom over 8 years ago
    THANK YOU
  • voltsandjolts
    0 voltsandjolts over 8 years ago
  • jaza_tom
    0 jaza_tom over 8 years ago in reply to voltsandjolts
    I do use that for most generic components, it's just the tricky ones that I need to do manually (i.e. SD card holders)
