Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Differential pairs in .SchDoc files...
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 2347 views
tonyshell
tonyshell over 8 years ago
  I've created a schematic and I'm trying to compile it.  I get the error "Compiler Missing Negative Net for differential pair [NetR5_1], positive net [NetR5_1]" for each wire that I have marked as a differential pair.  I know that I have to somehow designate a positive and negative wire for each pair, but how do you do that?  I used the differential pair directive to mark each wire, but I couldn't find anything where you match them.  There's no documentation for this!  Any help would be appreciated.
  • voltsandjolts
    0 voltsandjolts over 8 years ago
    You need to name your diff pair nets and append _P or _N.
    For example:
    mydiffpair_P
    mydiffpair_N
  • tonyshell
    0 tonyshell over 8 years ago in reply to voltsandjolts
    Thanks for the help.  I had read that about naming them with the appended _P and _N but didn't know where to do that.  I used differential pair directive and named them there, but compiling still gave me errors.  After I read your reply, I tried the net label and those errors are gone once I could get the net label on the wire.  Is this the proper/best way to do it?  Do I need both the net label AND the diff. pair directive on the wire?  Please let me know.
  • e14softwareuk
    0 e14softwareuk over 8 years ago in reply to tonyshell
    That looks to be correct. The directive lets the system know the nets are part of a differential pair, the naming convention of _P, _N allows the system to match up the marked pairs.
