Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Silk to BoardRegion Clearance design rule bug
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1358 views
  • design rule
  • circuitstudio
  • silktoboardregion
  • clearance
jaza_tom
jaza_tom over 8 years ago
I'm trying to set up a design rule in PCB layout editor.
I want to set up a rule that throws an error when any silkscreen layer objects are within X mils of the board outline
I think the rule type I want to create is a Manufacturing Rule -> Silk To BoardRegion Clearance rule, as in the following screenshot:
The problem is that there is no where to specify the minimum clearance value in this dialogue.  As far as I can tell, this dialogue has no user input fields other than the scope dropdown and the ability to change the rule name and add a comment.  Am I missing something?
  • voltsandjolts
    0 voltsandjolts over 8 years ago
    I see the same issue.
    I use a 1mm keepout around the board edge so never looked at this rule.
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    Hi Tom. I believe this rule is for items that are outside of the board region and not for detecting when close to other objects such as a board outline or keepout.
