Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum How do I sync removal of pin from a net between schematic capture and PCB layout
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1173 views
  • troubleshooting
  • sync
  • bug
  • circuitstudio
  • nets
jaza_tom
jaza_tom over 8 years ago
I have two nets:  LED_3 and CHARGE_DISABLE.  They are connected to pins 14 and 19 of my microcontroller, respectively.  I would like to swap the pinout such that now net LED_3 is connected to pin 19 and net CHARGE_DISABLE is connected to pin 14.
To be clear, I want the following:
- Open schematic layout document
- Disconnect net LED_3 from pin 14
- Disconnect net CHARGE_DISABLE from pin 19
- Connect net LED_3 to pin 19
- Connect net CHARGE_DISABLE to pin 14
If I apply the aforementioned changes to the schematic layout document, there doesn't appear to be any way to import those changes into the PCB layout document.
What am I missing?
Here is a video showing my problem (note you may have to select a higher resolution in the video settings options to make things viewable on your computer)
e14softwareuk
e14softwareteamvoltsandjolts
  • adamwebber
    0 adamwebber over 8 years ago
    I tried the same operation with my CS and could not replicate your results.  Mine works fine.  I'm sorry that I could not be of assistance.
    Version 1.4.1 (Build 99)
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    Hi Tom, what you are doing looks to be correct so not sure why it shouldn't be working for you. Normally I run the Update PCB Document from the schematic but that really should not make any difference. A couple of suggestions.
    1. Make sure the schematic and PCB components are in sync using Tools | Component Links from the PCB editor.
    2. Make a backup on your PCB and then try Tools | Netlist > Clear All Nets followed by updating the PCB from the schematic.
