Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Circuit Studio Parameter Manager and Footprint Manager??
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1108 views
turjohn
turjohn over 8 years ago
Am I missing it or does Circuit Studio not have the parameter and footprint manager tools that are available in Altium designer?  I get that this is a very stripped down version of Altium, but for $500 it's crazy to think they wouldn't include some of this basic functionality.  Can anyone recommend a better way to edit component parameters than going through each component individually and making the changes?
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    In general look to the object inspector to make mass changes to object properties although not everything can be changed using this technique.
  • cpinkers
    0 cpinkers over 7 years ago
    I'm also searching a solution for that.
    In my previous company I was using Alium. Now I'm trying CircuitStudio because of the price.
    How to generate a good BOM without being able to edit component parameters massively ?
    Did you find a solution ?
    Thank you,
    Christophe
  • mc6800
    0 mc6800 over 7 years ago
    If you know Altium Designer scripting, you might be able to create a script to open the library and add/modify parameters that way. Although it isn't made obvious, it seems as if CS has a degree of scripting available. You need to open the script *.pas file, and then use Run etc as commands typed in the search box to execute the script (there doesn't seem to be a menu option).
