Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum GKO file empty - bug??
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 2156 views
  • board outline
  • keepout
  • gerbers
alager
alager over 7 years ago
I have my board outline layer and keepout layer the same, however when I generate gerbers, they are both empty!  So of course my pcb is being rejected by the fab house!
I even checked the box for add the board outline to all plots, but NOPE, it's not there!  See images below for config and layer data.
I've not seen this behavior with my rectangular PCBs.
Is this a bug for round PCBs?
The keepout and board outline are identical, they contain an arc.
However, using gerbview, both of those layers are completely empty!
Thanks for any ideas on how to get the board outline to show up in my gerbers.
This is the content of my GKO file (pretty empty):
G04*
G04 #@! TF.GenerationSoftware,Altium Limited,CircuitStudio,1.5.1 (13)*
G04*
G04 Layer_Color=16720538*
%FSLAX25Y25*%
%MOIN*%
G70*
G01*
G75*
M02*
Aaron
  • alager
    alager over 7 years ago +1 verified
    I solved this. It looks like if the keepout box is checked, then it doesn't show up in the gerbers. I guess that makes sense, so that there aren't lines all over the place in the gerbers. Once I removed…
  • alager
    0 alager over 7 years ago
    Once I removed the check box, the lines showed up.  Not sure how this got selected for the board outline, but it was.  So once I removed that check as well, it too showed up.
  • voltsandjolts
    0 voltsandjolts over 7 years ago in reply to alager
    This is not a bug.
    Including the keepout in gerbers is not recommended practice.
    You need to draw the board outline on the outline layer using:
    Home tab > Board Shape > Create primitives from board shape
