Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Renaming components
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1154 views
  • renaming
Renaming components
lupal
lupal over 7 years ago
Hi all,
I am fighting with what I would expect a basic functionality.
I just need to rename components in my project.
So I for example I rename R56 to R36 in my schematic.
Then I update the board and I expect the component's name on the board changes.
But in many cases the components is like erased and inserted again. So I see it in the right bottom corner instead on the original place.
It is becoming a mess when renaming more components. I can just imagine what would happen if forcing complete schematic annotation.
Sometimes the process runs as expected. I think it has something to do with changed net names when changing the component - if they do not change, the name change works fine.
Comparing to eagle - I just rename the components on the schematic and everything is done automatically.
I use 1.4 version.
Am I missing a simple straightforward method?
Thanks a lot for help.
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    Before trying to synchronise the schematic and PCB you should run Tools | Component Links from the PCB editor to make sure all components are mapped correctly.
  • lupal
    0 lupal over 7 years ago in reply to e14softwareuk
    Hi Peter,
    thank you very much.
    I had trouble using Component Links. It was crashing all the time, but after Circuit studio restart it is running again and solves the problem.
    Lukas
