Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Gerber problem
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 899 views
  • gerber error
  • bug
  • gerber generation
Gerber problem
michele.francia
michele.francia over 7 years ago
I create a project compiled with no error but the gerber file have more problem, some dcode are no correct and have 0 value. This problem cause a wrong manufacturing board. Some track are absent, some pad are absent and a component pad is wrong.
This is a bug, and i spend money and time for resolve this problem. Please check the software converter to gerber file. it's a very serious problem.
Have a nice day
Michele
  • e14softwareuk
    e14softwareuk over 7 years ago +1
    Hi Michele, sorry to hear you have had problems. I would strongly suggest to always check the gerbers with a viewer prior to manufacturer or use a manufacturer who will produce check plots so obvious errors…
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    Hi Michele, sorry to hear you have had problems. I would strongly suggest to always check the gerbers with a viewer prior to manufacturer or use a manufacturer who will produce check plots so obvious errors can be detected. Without further information is it only guesswork as to what has gone wrong. Did you generate normal Gerbers and forget to include the aperture file? Perhaps you used extended gerber but had too many region shapes and ran out of dcodes? Were there any error messages (check the message window)? Did you select the correct layers to be generated and supplied them all? At this stage it is just as likely user error as being a software bug.
