Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Can't modify a document parameter visibility
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1763 views
carles.candela
carles.candela over 7 years ago
I'm working in a schematic document and I would like to include the document title in a text string (=Title parameter), but what I'm getting is the parameter name "Title =" before the parameter value. I found that custom added Parameters can be edited (Document Options - Parameters label)  so I can hide the parameter name visibility, but for some unknown reason I can't change the visibility of the some fixed document Parameters (checkbox is greyed out) , and visible checkbox is checked by default.
Does someone know a solution ?
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    Hi. Just taken a look and "Title" does not have visibility checked and when added to a schematic as text using "=Title" it will only show up the value of title and not the parameter name itself. Was your design originated in CircuitStudio or imported?
  • carles.candela
    0 carles.candela over 7 years ago in reply to e14softwareuk
    Hi Peter,
    Thanks for your answer, my document is imported from Altium Designer, I just checked the original file in Altium and is also greyed out and checked, so I have the same problem in Altium. I have the same problem with all the default document parameters. This problem doesn't appear in other schematics documents from the same project.
    Very weird
  • e14softwareuk
    0 e14softwareuk over 7 years ago in reply to carles.candela
    As you say it is very strange. Perhaps create a new document and copy across the relevant parts?
