Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Board Array Function
  • Locked Locked
  • Replies 8 replies
  • Subscribers 90 subscribers
  • Views 1856 views
tyro01
tyro01 over 7 years ago
Hi, I'm trying an evaluation version of CircuitStudio 1.5.
I'd like to panelize my PCB I designed to the large PCB.
Any FAQ on the net says CircuitStudio don't have a panelization function.
But I saw the working procedure at following video.
ttps://www.youtube.com/watch?v=lXM_3_9vTBI
In this video, he is calling an Embedded Board Array menu.
What I want to do, place 2x2 single design PCB on the panel,
and add 10mm margin to top and bottom, left and right
with 6 V-grooves. I'm not desired to make different PCB mixed array.
Can I do this on CircuitStudio?
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    Hi. There is no official support for this feature but see this other forum question.
    PCB panelization in CS
  • tyro01
    0 tyro01 over 7 years ago in reply to e14softwareuk
    Hi, Please let me know what he said from 2:20 to 2:25 on his tutorial.
    I can't hear his phrase though it's key action.
  • e14softwareuk
    0 e14softwareuk over 7 years ago in reply to tyro01
    You need to double click on the embedded array and then load in your PCB.
  • tyro01
    I understand that double click to call Embedded Board Array dialog after board array was placed.
    Prior to this, to paste an originl board design, I need to select original data include the board outline.
    Now, I prepared an completely-designed Original_PCB.CSPcbDoc and blank Panelized_PCB.CSPcbDoc.
    When I select all objects at Original_PCB, but it's not include board outline.
    Furthermore if I tried to repeat the paste, Referense Designator R1 is added as R1_2 and R1_3...
    So copy & paste does not work well. I'm sorry if I'm mistaken.
  • e14softwareuk
    Have you had someone provide you with the Embedded Board Array PCB document created by Altium Designer? You cannot simply copy and paste a CS PCB document multiple times.
  • tyro01
    No. But I understand functional restriction of CircuitStudio.
    Thank you for your reply.
  • lamabrew
    0 lamabrew over 7 years ago
    This may help: Recomendations on panelization software for user array and multiproject?
  • tyro01
    0 tyro01 over 7 years ago in reply to lamabrew
    Hi Brewstar, I downloaded PcbDoc template file from the thread, and did it according to his instruction.
    I got PCB array as I thought. Thank you very much.
