Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Dimension line in pattern
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 697 views
tyro01
tyro01 over 7 years ago
How to place dimension line in pattern like following picture?
I want to check relative position of all pads and the dimensions when I create a new pattern.
But CircuitStudio does not seem to have a dimension line tool.
And, simple measure tool can not snap to edge of the pad/primitive.
Please tell me if I make a mistake or misunderstanding.
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    The PCB library editor does not include the dimension tool. However you should be able to measure the distance between the edge of objects using Tools | Between Primitives.
  • tyro01
    0 tyro01 over 7 years ago in reply to e14softwareuk
    I understand. I'm used to place dimension line to check my design and compare with the recommended footprint.
    So I'm a little worried if I can't place dimension line to pattern directly.
    Thank you for your answer.
