Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Assembly and 3D layers not mirroring
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 706 views
hlovett
hlovett over 7 years ago
I have imported a design from EAGLE and have started modifying it. However, the Assembly and 3D Top layers do not translate to the Bottom equivalents on import or when the part is flipped (using 'L' when moving) and remain on the "top" even though the pads and overlay has translated. I have noticed this on multiple imports.
If I place a brand new part into the existing project, it behaves in the same incorrect manner.
If I place the library parts in a new board (started in CS), then everything is fine, so I am confident it is a board specific thing.
Interestingly, when I generate the assembly drawings, the Bottom assembly does not appear on the Top assembly document (even though they are all apparently on the same layer). The bottom assembly does not appear on the bottom drawing, though.
Is there any option that would cause this to behave like so? I have tried updating all of the PCB footprints from the library to no avail.
Any help would be much appreciated.
Henry
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    It might be worth checking out the mechanical layer pair mappings - accessed from the View Configurations dialog.
  • hlovett
    0 hlovett over 7 years ago in reply to e14softwareuk
    Perfect, that has fixed it!
    Thanks very much,
    Henry
