Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Defining a custom paste mask
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 671 views
tyro01
tyro01 over 7 years ago
I'd like to define a latticed paste mask to 5mm*6mm big pad.
Default paste mask has been defined based on the parameter of Paste Mask Expansion.
In fast, I changed this parameter to -3mm, and the pad shape has disappeared completely.
Next, I defined custom shape to another layer, and move to Top Paste layer.
It seems to be working fine. Is this official way?
tyro
  • tarribred61
    0 tarribred61 over 7 years ago
    Yes. You got it!
    If you put vias in the pad make sure to either fill and plate them or make the vias something like 10mil or less in diameter or somehow prevent the via from stealing solder off the pad.
  • tyro01
    0 tyro01 over 7 years ago in reply to tarribred61
    I'll be careful when I create vias embedded pad. Thank you very much!image
