Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum How to generate Top/Bottom column on BOM?
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 3901 views
tyro01
tyro01 over 7 years ago
I'm trying to mount parts to double-sided PCB using cheap stencil and tweezer.
I need a parts list separated from Top and Bottom side.
I checked [Project]-[Generate outputs] dialog, but I can't find "Mount Side" or usable column.
How can I generate my list with the mount side?
Desired CSV data format as shown below:
"R1,R3",2,RR0816,Top
"R2,R4,R5",3,RR0816,Bottom
tyro
  • voltsandjolts
    0 voltsandjolts over 7 years ago
    Project > Generate Outputs > Configure BoM
    Select "Include Parameters From PCB" at bottom left of window.
    In parameter list check "Layer" which adds a "Top/Bottom" column to BoM
  • tyro01
    0 tyro01 over 7 years ago in reply to voltsandjolts
    I did it! Thank you very muchimage
    tyro
