Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Feedback - some simple suggestions
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 507 views
jwdtemp
jwdtemp over 7 years ago
Using CS for about one month.  Previous experience 4 years AD
A few simple updates that would improve user experience
1      When displaying a user local library in projects area this should be in alphabetic order - not random as it is at present ie similar to AD
2      Also need alphabetic sort when selecting a footprint for a schematic
3     when on pcb layout - right click to be able to select an 'origin' and/or  change imperial to metric (Ad uses shortcuts)
4     Need a 'File Save As' facility - pretty urgently!!
can supply screen shots of issues if required
Julian Dinsdale
  • tarribred61
    0 tarribred61 over 7 years ago
    Good suggestions.
    1) I think it does sort alphabetically if you click on the column header within the SCH Library view.
    3) You can do change imperial/metric with keystrokes, it is a bit cumbersome (Alt-h G M or Alt-h G I) but not too bad once you do it enough it becomes something you don't think about.  Sometimes you can use CTRL-Q to flip between imperial and metric; this method works in submenus but not from the main PCB window.
    4) If you mean a 'File Save A Copy As' then I agree it would be helpful.  Instead I just go out and do it within Windows.
  • jwdtemp
    0 jwdtemp over 7 years ago in reply to tarribred61
    Thanks for the feedback
    unfortunately I still cannot find any facility to sort alphabetically.  I agree the library pane on the RHS of my screen can be sorted.but the library schematic and footprint files cannot.  In AD there is a button to sort this.  It feels like the software designers just don’t care or they have never used CS in the real world.
    thanks for the info re the keystrokes.  I think it will be easier to clunky go to the menus !!
    Yes , “Filr Save a Copy As” would be really useful
