Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Editor schema: come collegare un segnale in più pagine
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 415 views
michele.francia
michele.francia over 6 years ago
Buongiorno a tutti, sto cercando il metodo corretto per collegare un segnale generato dal collettore di un transistor che deve essere inviato a diversi ingressi di led controller in altre tre pagine. Non riesco a trovare quale sia il metodo, infatti ad ogni compilazione mi vengono mostrati errori.
Ho provato con le porte, ma poi mi viene restituito l'errore di porte multiple connesse, ho provato col NetLabel ma viene restituito Floating Input Pin.
Non riesco a trovare la soluzione neanche nella guida. Come si può risolvere?
Saluti
Michele Francia
  • tarribred61
    0 tarribred61 over 6 years ago
    Translation to English based on Google Translate:
    "Good morning everyone, I'm looking for the correct method to connect a signal generated by the collector of a transistor that must be sent to different inputs of LED controllers on three other pages. I can't find what the method is, in fact at every compilation I am shown errors.
    I tried with the ports, but then I get the error of multiple connected ports, I tried with NetLabel but Floating Input Pin is returned.
    I can't find the solution even in the guide. How can it be solved?"
    This sounds like an issue with either hierarchical design settings or settings of electrical rules checking (ERC) and how the various pins are defined as inputs, outputs, passive, etc.  I don't think the errors you see stop the compilation.
    Here is an older tutorial on multi-sheet design.
    Tutorial - Multi-sheet Design with Altium CircuitStudio
    Information on electrical rules checking and compilation:
    Project Options - Error Reporting | Online Documentation for Altium Products
    Electrical Rules Check Setup | Online Documentation for Altium Products
