Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum How to set Schematic Title
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 2724 views
johninjax
johninjax over 6 years ago
Hey,
  Just started using Circuit Studio. I've created a schematic. I set the title in the document parameters, but it doesn't update in the schematic. What am I doing wrong?
  • tarribred61
    tarribred61 over 6 years ago +1 verified
    Hi, Do you have a text string on the schematic that will print out the name? There should be a text string placed that has the text =title in it. These are considered as special strings by Altium. There…
  • tarribred61
    0 tarribred61 over 6 years ago
    Do you have a text string on the schematic that will print out the name?  There should be a text string placed that has the text =title in it.  These are considered as special strings by Altium.  There is a check box in the layer configuration settings to control visibility of these by controlling whether they are converted to the designated text in the screen view.
    This link should describe it better than I can.
    Text | Online Documentation for Altium Products
    If you have multiple schematic sheets in the project you need to set each one up individually.  That is, each can have its own title.
