Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Outputs (BOM) for only one PCB of the Project
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 2481 views
  • bill of materials
  • multiple documents
  • outputs
  • circuitstudio
jonasschmidt
jonasschmidt over 6 years ago
I have a project consisting of multiple schematics and pcb documents.
Is there a way to generate outputs only for one set of docs (i.e. 1 sch + 1 pcb)? Most of all I need this for the generation of the bill of materials (BOM).
Until now I am using a workaround of copying fils to blank projects before generating outputs which is not very practical
Thanks in advance
Jonas
  • jonasschmidt
    jonasschmidt over 4 years ago +1 verified
    I found a solution: 1. Configure and generate the output. 2. Locate the project directory in your file explorer and find the (freshly generated) .OutJob file 3. Edit the .OutJob file with an editor (notepad…
  • frog
    0 frog over 6 years ago
    It's my understanding that CS is designed for only one PCB per project, for the reasons you've pointed out.
  • jonasschmidt
    +1 jonasschmidt over 4 years ago
    I found a solution:
    3. Edit the .OutJob file with an editor (notepad++)
        OutputDocumentPath1=MySchem.SchDoc for BOM
        OutputDocumentPath2=MySchem.SchDoc for Schematic
        I haven't used this feature for PCB-files yet.
    Sometimes it doesnt work on the first try. You might have to close the CS "generate outputs" dialogue oder even the project. If there is a typo in the OutJob file, all schematics will be used for the output.
    Caution: all this sometimes leads to data loss. Make sure to have backups!
    TRANSLATE with x
    English
    Arabic Hebrew Polish
    Bulgarian Hindi Portuguese
    Catalan Hmong Daw Romanian
    Chinese Simplified Hungarian Russian
    Chinese Traditional Indonesian Slovak
    Czech Italian Slovenian
    Danish Japanese Spanish
    Dutch Klingon Swedish
    English Korean Thai
    Estonian Latvian Turkish
    Finnish Lithuanian Ukrainian
    French Malay Urdu
    German Maltese Vietnamese
    Greek Norwegian Welsh
    Haitian Creole Persian
    TRANSLATE with
    COPY THE URL BELOW
    Back
    EMBED THE SNIPPET BELOW IN YOUR SITE
    Enable collaborative features and customize widget: Bing Webmaster Portal
    Back
