Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum How to swap pins between components ?
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1563 views
  • pins
  • pin swapping
  • swap pins
julach
julach over 5 years ago
I would like to simplify the routing of my board, and I don't mind the pins being changed on the connectors.
I read this on the altium support : https://www.altium.com/documentation/altium-designer/pin-pair-and-part-swapping-ad
And this on the circuitstudio support : http://documentation.circuitstudio.com/display/CSTU/PinSwapper_Dlg-ConfigureComponentPinSwap((Configure+Pin+Swapping+for…
But I still can't do what I'd like to do...
In their example, the swap pins in one component, in my case, I would like to swap pins between 2 components, and not obligatorily, all of them.
Is it possible to do this without doing it by hand ?
Thank you.
  • jmarkwolf
    0 jmarkwolf over 5 years ago
    I don't know if this will work for your application or not, but I have always accomplished a similar thing by editing the schematic and/or re-sequencing (re-assigning) schematic symbol pins in the library, the updating the PcbDoc. Much of time it will have the effect of unscrambling tracks around many PCB components (very useful on microcontrollers). And you won't have to mess around with pin-swapping on PCB parts.
  • julach
    0 julach over 5 years ago in reply to jmarkwolf
    Hi, thank you for your answer !
    Ah so you move the pins in the component library ?
    But in my case I want to use multiple time this component and the pin switching will be different every time.
    I think this solution will not be possible for me ?
