Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum What is the most efficient way to duplicate a .SchLib and .PcbLib within CS?
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1089 views
stuartrumley
stuartrumley over 5 years ago
What is the most efficient way to duplicate a part in order to preserve properties when creating new parts or part variants within a library?  Save as behaves as Rename, there is no copy paste.
Is the proper way to just copy the files using Windows Explorer and then open the library file in CS and add the file to the .LibPkg? Seems like there should be a more streamlined way to do this.
Thank you,
Stuart
stuart@valontechnology.com
  • tarribred61
    0 tarribred61 over 5 years ago
    Yes, use Windows to make a copy just like any other file.  CS does not have a menu toolbar to save a copy as.
    However, if you want to do it from CS then go to the search bar and type in "save copy as".  The ability is there if you want to do it that way.
