Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum altium content vault
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 1385 views
nicolaialexandrov
nicolaialexandrov over 5 years ago
is it normal that when i search the vault whit some precise search criteria , i obtain 23654874328564328754 irrelevant results ???
let say i searc for RES 330r 0805 5% and i have more than two pages whit all kind of resistors ?
am  i doing something wrong ?
  • nhee
    0 nhee over 5 years ago
    Are you using the search tab in the lower left corner of the Vault window?  Just curious as I have not been able to make it work at all.
    Your search should return a simple AND of your search terms.  It sounds like it's broken.
  • nicolaialexandrov
    0 nicolaialexandrov over 5 years ago in reply to nhee
    Following you question i found my problem... i was on Structure tab when i switched to search it works for me,
    what is your  problem exactly ? Are you logged in you account ?
    I found that if you log in as you open the software it works well, but if you start working and try to edit a part while not yet logged it gives you a vault error, but then even if you log-in it wont work properly
    Good luck
  • nhee
    0 nhee over 5 years ago in reply to nicolaialexandrov
    Glad you fixed it !
    I had edited my question while you were responding.  In general, the search tab causes CS to freeze for a while (a minute or more).
    I was able to search for 0402 1% successfully so I now know that it works at least.  Just have to remain patient.
  • nicolaialexandrov
    Yep, it is slow (sometime painfully slow) I think that their database is huge, and it look like that while it searches you can't even stop the process...
    I have to say that I lost faith in the vault, usually I draw my own parts, sometime I get lucky and are able to find the wright part...
