Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum UNKNOWN PIN ERROR - I've read the previous threads....
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 4945 views
dmjohns2012
dmjohns2012 over 5 years ago
I'm having trouble updating my PCB from the schematic, getting the "Unknown Pin" error and "failed to add class member" error.
I have read the previous threads.
This problem is ONLY happening with my resistors from my integrated resistor library.
#1 - YES, my schematic decal pin numbers match my footprint pin numbers.  Do not suggest this is the problem.  It is something else.
#2 - YES, the footprint is properly linked to the schematic symbol.  The footprint and the 3D body is visible in the library window.  Do not suggest this is the problem.  It is something else.
#3 - NO, the schematic component type is not set to "mechanical." It is set to "Standard."  Do not suggest this is the problem.  It is something else.
#4 - YES, I have rebooted the program, it did not help.
#5 - YES, I have saved and compiled the resistor library.  It did not help.
#6 - I have even started a NEW library project, copied over the resistor schematic library and the Pcb library, and re-linked all the footprints.  All the pin mappings are good: 1 -to- 1 and 2 -to- 2.... then saved and recompiled the new resistor library.  This did not help.
...when I say "this did not help"... I deleted one or more of my problem resistors, replaced the resistor from the integrated library, or new integrated library, saved and recompiled the project, then tried to update the components in the PCB...
Please - what is the problem??
  • dmjohns2012
    0 dmjohns2012 over 5 years ago
    Found this:
    https://electronics.stackexchange.com/questions/167140/altium-summer-09-unknown-pin-errors
    just wow.
