Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Generate Project Output deletes all project folder files
  • +1 person also asked this people also asked this
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1056 views
  • pdf
  • error
  • deleted files
  • project output
carles.candela
carles.candela over 7 years ago
I'm trying to generate Schematics PDF's from a project.
When I press the "Generate" button in the "Generate output files" dialog box, an Error message appears with this: "Can't create Default Configuration\..\G500 - UJI\G500 - UJI.PDF: El sistema no puede encontrar el archivo especificado".
After pressing OK, another error message: "Validation failed".
After this, when I open the project folder in the windows file explorer. All the files in the project folder are gone, deleted. Project folder exists but it's empty.
From Circuit Studio, the project files are still opened and can be saved as if they were new files.
If I generate the PDF output files individually, printing every single sheet. Everything is OK. No errors, no deleted files.
I'm attaching a recorded screen showing the described error.
Hope you can help me,
Carles.
  • e14softwareuk
    0 e14softwareuk over 7 years ago
    Not sure what's going on but could be some 'corrupt' paths in the project or output job file. I would suggest testing by creating a brand new project and manually copy over the schematic and then use add to project. Once complete try the output generation again.
