Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Copying and pasting LAYER_NAME variables as in Keithley Scanner example
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1136 views
nhee
nhee over 5 years ago
The Keithley 20 channel scanner example has a cute list of visible layer names in the upper left corner, which in single layer mode, lights up the layer that you are on.
Actually quite handy.
A simple cut and paste into my pcb design does not function.  All of the layers show "LAYER_NAME" instead of the actual name of the active layer.
What would I need to do to carry whatever references are needed to make this work to my design?  Is some option involved or a statement linking things?
  • nhee
    0 nhee over 5 years ago
    Actually, I just found the answer and will post it here for posterity.
    When you go into "view configurations", in the third tab called "view options", you need to check "convert special strings".
