Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Importing a DXF file, but NOT for board geometry
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1490 views
dmjohns2012
dmjohns2012 over 4 years ago
I'm trying to import a DXF file as an ANSI B print template on the Drill Drawing layer.  When I import the file and select to map the AutoCad layer 0 to the Drill Drawing layer, the file comes in, and Circuit Studio changes the board outline to the extents of the DXF file - 11x17.   How do I import a DXF file without the software presumptuously assuming I want to make the board outline from the DXF file?
  • erix
    erix over 4 years ago
    I usually start a new PCB file, import the DXF into it, select the geometry I want (change layers if needed), copy them and paste them into the real PCB document.
