Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Generating Output for all Variants
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 955 views
  • variants
  • generate outputs
ErikZ
ErikZ over 4 years ago
Hello
I designed a Circuit/PCB which has 4 variants (different gain resistor combinations). Now I want to generate the Output files to all the variants. How it is now, I have to:
go to Generate Outputs->select Choose a single variant-> Choose the variant -> click on Generate -> wait an awful long time for just creating pdfs and an excel file -> Go to the folder the outputs were generated in -> Copy the generated files into a seperate folder
and do that over and over again.
Is there a setting i havent found yet so I can just press a button and it generates all files for all variants without all the hassle? They are already named correctly, with a specific filename for every variant (except for the pdf), so I might have missed an option to switch off that CS always clears the whole folder before generating the output files.
Because of the variant feature not being very powerful i had to have 4 projects in parallel where I have to do all the steps again, so you can imagine shortening this process in any way would save me a lot of time
Thanks in advance
  • jonhpeterson
    jonhpeterson over 4 years ago
    ErikZ It's a good requirement and I haven't seen any good solution within CircuitStudio. I do hope that Altium folks are reading this forum regularly. While CS doesn't cost what Designer does, we are still good customers of Altium and we need each other to succeed.
