Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum footprint via not connecting to pad Net
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 2891 views
  • footprint
  • vias
pizutti
pizutti over 4 years ago
Hi!
I have a footprint with an exposed pad and thermal vias under it, but the vias are not connecting to the pad Net, I already have other components with exposed pads and thermal vias and all of them work just fine, as soon as their are added to the PCB, all vias are connected automatically, any idea what could be happening?
this is the footprint:
on the PCB:
this is an example of a footprint working just fine:
as you can see, all vias get the GND Net, internal GND plane and bottom are connected as well, and on the other component they do not have any connection.
  • pizutti
    pizutti over 4 years ago +1
    Found the problem! my footprint had an incorrect type of Net Tie, just switched to Standard and all went fine!
  • tarribred61
    tarribred61 over 4 years ago
    Maybe check for rules that are preventing connection.  Can you connect it manually without getting a rule violation?
    Also check for keepouts.  From the picture it looks like there may be a keepout around the vias in the pad.
  • pizutti
    Found the problem!
