Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Board Cutout from selected object
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 1427 views
tiopepe
tiopepe over 4 years ago
Hi all,
I would to place a board cutout from dxf file: there is a way to create a board cutout from selected object?
Thanks at all for the support
  • GabeFromSpace
    0 GabeFromSpace over 3 years ago
    I don't think there's any way to import a cutout like that, but I've used the different "placement modes" useful for creating non-square cutouts.
    https://documentation.circuitstudio.com/display/CSTU/PCB_Obj-BoardShape((Board+Shape))_CS
    If you have something really complex, you can design your outer board shape, and generate your outline layer (Create primitives from board shape). Then for your cutout, go File > Import. Then import your DXF to your outline layer. Your polygon pours won't avoid it and it won't show up in 3D right, but when you convert it to a gerber, the PCB fabs should understand what to do.
