Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum How to specify Differential Pairs in Multi-Channel design _1 versus _N
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 2187 views
  • differential pairs
  • multichannel schematics
  • differential signals
  • multi-channel
  • circuitstudio
felixcollins
felixcollins over 3 years ago
I have a multi-channel design using hierarchical sheets and the Repeat() operator. I have two banks of two channels for a total of four channels. Each channel needs a USB DP/DN pair connected from the top level. As far as I can tell this is impossible despite being a fairly common requirement. The multi-channel feature requires the appending of _1,_2,_3,_4 to the net names and the Differential pair feature requires the appending of _P,_N to the net names. I end up with a bunch of compile errors.
Is there any way around this or is it just an inherent limitation of Circuit Studio?
Class    Document    Source    Message    Time    Date    No.
[Error]    Top_Level.SchDoc    Compiler    Missing Negative Net for differential pair [USB_D_P_1_1], positive net [USB_D_P_1_1_P]    4:46:18 PM    7/12/2022    13
[Error]    Top_Level.SchDoc    Compiler    Missing Negative Net for differential pair [USB_D_P_1_2], positive net [USB_D_P_1_2_P]    4:46:18 PM    7/12/2022    14
[Error]    Top_Level.SchDoc    Compiler    Missing Negative Net for differential pair [USB_D_P_2_1], positive net [USB_D_P_2_1_P]    4:46:18 PM    7/12/2022    15
[Error]    Top_Level.SchDoc    Compiler    Missing Negative Net for differential pair [USB_D_P_2_2], positive net [USB_D_P_2_2_P]    4:46:18 PM    7/12/2022    16
[Error]    Top_Level.SchDoc    Compiler    Missing Positive Net for differential pair [USB_D_N_1_1], negative net [USB_D_N_1_1_N]    4:46:18 PM    7/12/2022    17
[Error]    Top_Level.SchDoc    Compiler    Missing Positive Net for differential pair [USB_D_N_1_2], negative net [USB_D_N_1_2_N]    4:46:18 PM    7/12/2022    18
[Error]    Top_Level.SchDoc    Compiler    Missing Positive Net for differential pair [USB_D_N_2_1], negative net [USB_D_N_2_1_N]    4:46:18 PM    7/12/2022    19
[Error]    Top_Level.SchDoc    Compiler    Missing Positive Net for differential pair [USB_D_N_2_2], negative net [USB_D_N_2_2_N]    4:46:18 PM    7/12/2022    20
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_N_1_1_N has only one pin (Pin IC1-1)    4:46:18 PM    7/12/2022    21
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_N_1_1 has only one pin (Pin X1_J6-30)    4:46:18 PM    7/12/2022    22
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_N_1_2_N has only one pin (Pin IC1-3)    4:46:18 PM    7/12/2022    23
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_N_1_2 has only one pin (Pin X3_J6-30)    4:46:18 PM    7/12/2022    24
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_N_2_1_N has only one pin (Pin IC1-6)    4:46:18 PM    7/12/2022    25
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_N_2_1 has only one pin (Pin X2_J6-30)    4:46:18 PM    7/12/2022    26
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_N_2_2_N has only one pin (Pin IC1-8)    4:46:18 PM    7/12/2022    27
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_N_2_2 has only one pin (Pin X4_J6-30)    4:46:18 PM    7/12/2022    28
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_P_1_1_P has only one pin (Pin IC1-2)    4:46:18 PM    7/12/2022    29
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_P_1_1 has only one pin (Pin X1_J6-28)    4:46:18 PM    7/12/2022    30
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_P_1_2_P has only one pin (Pin IC1-4)    4:46:18 PM    7/12/2022    31
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_P_1_2 has only one pin (Pin X3_J6-28)    4:46:18 PM    7/12/2022    32
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_P_2_1_P has only one pin (Pin IC1-7)    4:46:18 PM    7/12/2022    33
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_P_2_1 has only one pin (Pin X2_J6-28)    4:46:18 PM    7/12/2022    34
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_P_2_2_P has only one pin (Pin IC1-9)    4:46:18 PM    7/12/2022    35
[Error]    Top_Level.SchDoc    Compiler    Net USB_D_P_2_2 has only one pin (Pin X4_J6-28)    4:46:18 PM    7/12/2022    36
The hub sub-sheet with the differential pair definitions
The mid level of the hierarchy of sheets (bottom level of hierarchy is not shown but is similar)
The top level
  • felixcollins
    0 felixcollins over 3 years ago
    Found this for AD...
    https://www.youtube.com/watch?v=Swb-44_JVps
