Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum I want to move the coordinate origin of the PCB freely
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 7950 views
tyro02
tyro02 over 3 years ago
Hello everyone.
The origin of the PCB is fixed at the bottom left of the editing screen after create a new PCB.
Fixed origin
The PCB expands and contracts starting from the bottom left-hand corner of the editing screen.
However, movement is restricted as if caught in something. I prefer to edit with the board in the centre of the screen.
I do not believe this is a bug, but simply a configuration issue.
Can someone please solve this problem?
tyro02
    e14 Contributor over 3 years ago +1
    Hi. Not sure if this is what you are after but you can manually set the origin. Select 'Set' and then move the cross hairs to the new location and left click, or select 'New Location' and enter the…
    Select 'Set' and then move the cross hairs to the new location and left click, or select 'New Location' and enter the X,Y values.
  • tyro02
    tyro02 over 3 years ago in reply to e14 Contributor
    Thanks alijaki,
    Hmm, Still feel a tugging on the left side. Can I do this?
    CircuitStudio
    tyro02
    e14 Contributor over 3 years ago in reply to tyro02
    Home->Board Shape->Move Board Shape?
  • tyro02
    Thanks alijaki, I got the results I wanted by combining your advice.
    1) Home -> Board Shape -> Move Board Shape
    2) Home -> Grids and Units -> Origin -> Set(in the lower left corner of the board)
    The problem is solved, but it is strange that the board cannot move freely within the editing window.
    Anyway, thanks for the helpful advice!
    tyro02
