Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum generated outputs not in order of sheets
  • State
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 783 views
ulao2
ulao2 over 3 years ago
When I do my output generation my sheets are not in any understandable order.
I have:
1) my sheets are arranged left to right in order on my tabs ( guessing nor relevant)
2) My sheets are in the project tree top to bottom. ( guessing nor relevant)
3) I have labels on my sheet in the bottom right ( guessing nor relevant)
4) under sheet parameters I put in sheet number and sheet total. 1 : 6,  2 : 6,   3 : 6: etc...
I still get the order 2,1,3,6,4,5 when in pdf.
  • GabeFromSpace
    0 GabeFromSpace over 3 years ago
    Generally, the order in check you initially create sheets determines how the PDFs are generated. So if you create "main.SchDoc" first, then you create "secondary.SchDoc" second, the PDFs will add them in that order. I've tried looking at the different files in notepad, but none of the edits I've done seem to affect the PDF order. My recommendation would be to copy all of the content from your page 2, paste it into page 1, copy 1 into 2, 5 into 4, etc.
    0 e14 Contributor over 3 years ago
    Hi.
    By sheet parameters did you mean Tools->Number Sheets where you can map SheetNumber to DocumentNumber ?
    The PDF print should be in SheetNumber order.
