Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Why are my mechanical layers missing?
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 2531 views
  • circuitstudio 1.5
  • altium
  • pcb
  • bug
  • circuit studio
  • altium circuitstudio
GabeFromSpace
GabeFromSpace over 3 years ago
I'm trying to work with some mechanical layers on my PCB, but I can't find where to enable or disable them.
I've read that the "View Configurations" > "Board Layers and Colors" is supposed to look like this:
Where you can enable and disable all of the different layers, but my menu looks like this:
It's like none of the mechanical layers are enabled. When I uncheck the "only show enabled mechanical layers" box, nothing changes. Any tips on how to enable mechanical layers?
    dougw over 3 years ago +1
    I know nothing about Circuit Studio but saw this: if display of the sheet is disabled – by disabling the Display Sheet option in the Board Options dialog, then the linked mechanical layer(s) will also…
    e14 Contributor over 3 years ago +1
    Hi, I don't think this is just a matter of turning on mechanical layers - the entire dialogue is missing, and your system colours dialogue too. When I disable all mechanical layers I still get the dialogue…
    e14 Contributor over 3 years ago in reply to GabeFromSpace +1
    That really doesn't seem right, especially the System Colors options, I can't even think of why there should be an option to turn them off? Have you tried a re-install of CS 1.5.2?
     if display of the sheet is disabled – by disabling the Display Sheet option in the Board Options dialog, then the linked mechanical layer(s) will also be hidden.
    I don't think this is just a matter of turning on mechanical layers - the entire dialogue is missing, and your system colours dialogue too. When I disable all mechanical layers I still get the dialogue header (Layer, Color, Show, Enable etc.). I think either CS 1.5.2 or the project is broken.
    Is this just with one project or is it like this with everything?
  • GabeFromSpace
    GabeFromSpace over 3 years ago in reply to e14 Contributor
    This is with everything. When I create a new default project with a new default PCB, that part of the dialog is missing.
  • GabeFromSpace
    Uninstalling it and re-installing it worked! Thanks!
