Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum exporting mechanical layers
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1429 views
ulao2
ulao2 over 3 years ago
How do I export a exporting mechanical layer? The production house says its missing. Is it an option in gerber somewhere?
  • GabeFromSpace
    GabeFromSpace over 3 years ago
    When you click "Generate outputs" next to "Gerber Files", click "Configure..." then go to the layers tab. You can select any enabled layer from there.
    That being said, I presume that your production house is saying that they need your outline file. To generate an outline, open your PCB file, then under the home tab, open the dropdown menu and click "Create primitives from board shape". A window should pop up asking you what layer to put your outline on, and what line thickness to use. The line thickness is irrelevant to board houses, but it helps with visuals if you make it a few mills thick.
  • ulao2
    ulao2 over 3 years ago in reply to GabeFromSpace
    When I click ok it closes, where is the file?
  • GabeFromSpace
    GabeFromSpace over 3 years ago in reply to ulao2
    All of the output files will be in the projects folder under: "Project name"\Default Configuration\Outputs
    The boardhouse usually needs the Gerber and NC Drill files. So you can copy all the files from both into a zipped folder, then send them that. That being said, It's good to double check that the gerber files look normal in a separate program before you send them. I usually use Gerbview but the gerber viewer in KiCad works as well.
  • ulao2
    I'm using a online view that works with existing Gerber files. but this is what I see.
    The add shapes I do not really understand but the main issue is the part outlines. The factory says the parts the hang over should not be part of the shape.
  • ulao2
    ulao2 over 3 years ago in reply to ulao2
    ah I got it, had to use just outline and same for gerber options.
