Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum edited my footprint and SCH shows change but not PCB
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1646 views
ulao2
ulao2 over 3 years ago
To make an edit, I loaded the IntLib file. Then on the footprint I make my changes. I then do a compile and save. Now if I do a refresh in my library it picks up the change. So I remove the part from the schematic and place the new part down. It shows the change in the footprint view in the library  but my PCB does not show the3 change? Did I miss a step?
  • GabeFromSpace
    GabeFromSpace over 3 years ago
    Whenever I change a footprint, I update the library the way you did, then I delete the component from the schematic and add a new updated one. If there's a way to just update all open schematics to the most up-to-date version of the symbol, I'd love to know.
  • ulao2
    ulao2 over 3 years ago in reply to GabeFromSpace
    This is what I did but the update didnt cross over to the PCB after using the update pcb doc option.
    on sch.
    on pcb
    granted the part is issue but cleanly not the same part
  • GabeFromSpace
    GabeFromSpace over 3 years ago in reply to ulao2
    Try removing the footprint from the symbol in the Schlib, and add the footprint to the symbol again. Save and recompile the library. Delete the component from the schematic. Update the CSPCBDoc. Add the component back to the schematic. Then update the CSPCBDoc again. If that doesn't fix it, I don't know what will.
  • ulao2
    no luck but I figure maybe I can save the lib and re import it. The file I have and can use is called intlib but when I save my compile its libpkg, how can I save as intlib?
