Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Not-fitted components visible on the paste layers
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 2559 views
  • variants
  • circuitstudio
obywatel_lk
obywatel_lk over 3 years ago
The PCB company called  me and that they have an issue. I have a PCB with variant that goes to manufacture a stencil. In a variant view I don't see components in 3D view and that is OK. I see them on top paste layer. Bom is correct - no not fitted components. Pick and place files are OK.
Here is a 3D view:
Here is a top paste layer:
I have "hide not fitted components option" checked
I have a variant ON:
I'm generating outputs with variants:
I have all components matched:
No warnings, no errors.
Could you tell me what is wrong and if it is a CircuitStudio bug?
  • charlieo21
    charlieo21 over 3 years ago in reply to obywatel_lk +1
    I have seen in various PCBs that there's paste in the DNP footprints, it doesn't hurt having paste in the pads and if in the future you want to populate a part the paste is already there. Removing the…
  • GabeFromSpace
    GabeFromSpace over 3 years ago
    What did the PCB company say their issue was?
    Also, if those circular pads are for probing with a multimeter, test fixture, etc. I'd recommend removing their paste. Solder paste has flux in it that can leave a hard nonconductive coating over solder joints which makes it difficult to probe.
  • obywatel_lk
    obywatel_lk over 3 years ago in reply to GabeFromSpace
    Hello Gabriel,
    Thanks for quick answer. They saw a paste on test points - and there should be no paste so good catch. My issue is, that the paste is on the all not fitted components (top paste / bottom paste layer), so they almost manufactured a stencil with all components (Even these not fitted) despite the variant is correctly turned on and gerber files are generated specifically for this variant.
  • charlieo21
    I have seen in various PCBs that there's paste in the DNP footprints, it doesn't hurt having paste in the pads and if in the future you want to populate a part the paste is already there. Removing the paste from the DNPs would require another stencil, having paste in all the pads only need one stencil.
  • GabeFromSpace
    GabeFromSpace over 3 years ago in reply to obywatel_lk
    Like Charlieo said, putting solder paste on DNP components shouldn't hurt. With my footprint library, solder paste of choice, and stencil preferences, an 0603 takes less than $0.00045 worth of solder paste. Not really something to worry about unless you have dozens of DNPs & you're making tens of thousands of boards.
    For the test points, everybody has their unique design & library preferences. But I generally make a "test point" library component to put in the schematics, then I set the "Paste Mask Expansion" on the pad in the footprint to -10mm, so it effectively gets rid of the paste layer.
  • obywatel_lk
    Thank you for all replies. I created a pad class for all unwanted pads and removed the paste by adding a clearance in "Past Mask Expansion Rule". The question is whether this is the intended implementation of the functionality (?)
