Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Autorouter question
  • Locked Locked
  • Subscribers 90 subscribers
  • Views 950 views
Autorouter question
mkefalas
mkefalas over 10 years ago
Recently I decided to try Circuitmaker so if satisfied i could buy circuistudio  .
As i understand these are similar programs so testing circuitmaker  would be the same as testing CircuitStudio
I made a very small project pcb with 2 ics.
I found the whole process quite easy and everything was fine until I decided to check
autorouter . On first pass I selected  2 layer main and autorouter finished pcb with 0
contentions and violations.
I wanted to optimize routes so I decided to use cleanup strategy  which ,as I checked , straightens tracks
. After executing command a  vias has disappeared but the lines the via was  connecting remained
in their place .
After that I decided to rerun  2 layer main and the result  was a total mess with lines shorting and in other tracks
creating antennas . It was a total mess after a few runs. The messages were equally confusing indicating that
everything is ok .
Can anybody  understand what is happening ?. I can't figure it out the basic principles and from manuals I could not
find anything  .Are there any guidelines to make effective use of the Autorouter?.
If programs behave differently sorry for the question .
  • clem57
    clem57 over 10 years ago
    See From Idea to Manufacture - Driving a PCB Design through CircuitMaker | Documentation | CircuitMaker  for guidance where autorouting is setup and then used. A lot of tips to help you here,
    Clem
  • mkefalas
    mkefalas over 10 years ago in reply to clem57
    Dear Clem ,
    Thank you for the information .At this point i can't  say i have any useful results from the autorouter . My notion is that autorouter is the most
    productive part of the pcb design process so it should help the engineer as much as possible . The biggest problem i see is that running the
    autorouter more than once or in a half manually routed board creates a mess rather than optimizing things .
    I really consider buying circuitstudio but this is one of the most important parts of pcb design so it must operate flawlessly .
    ARe there any other sources of information  that could help me understand and use the autorouter .
    Best regards
    MIchael
